http://www.zx14ninjaforum.com/userfiles/prehme/car%20project%202%2020167.jpg Ride This !! ZX14R motor installed
Created on: 01/12/17 02:12 PM
prehme
prehme
RE: ZX14R F1 Car
01/13/17 11:20 PM
The body will be 20 gauge aluminum riveted to the frame with removable panels for access. And the back will be covered with aluminum on the top and upper sides with intake scoops for the 2 radiators on the upper rear sides. The upper role bar will be sticking above the covered aluminum back. There will be a rear wing the width of the inner wheel base by 24 inches long. There will also be a wing in front of the front tires for down thrust the width of the front tires. Take a look at an early 1980s F1 car and it will give you an idea of the look. I'm thinking of doing a vinyl wrap in Kawasaki green and yellow with my numbers 22 and all the manufacturer stickers on it including BMW because that's the differential spider gear set up I used for the rear end.
prehme
